Exdeus
- Apr 2, 2013
- 191
- 135
- 2017 RAM 2500
- Cummins
Hey All -
Just upgraded from a 1500 to a 2500 Cummins. Pick it up tomorrow evening. I have a few questions I was hoping you can help me with.
Lastly, in regards to getting the Cummins, I hear a lot about deleting and tuning. I am not looking for high speed or rolling coal, not my thing. I will be offroading and taking this on long range camping/expedition trips. Is there a value in getting a tune on the truck, and if so, which one? Most of my driving will be highway to get to location, followed by light to moderate offroading.
Thank you all in advance! I have a lot of questions on the diesel so I'm sure I will have plenty more!
- The wife and I are upgrading from a rooftop tent to possibly a truck bed camper (likely a pop-top Palmino or Four Wheel Camper with flatbed). I CANNOT find a 2017 RAM camper guide. The 2016 I have found lists GVWR using some code I cannot figure out what it is. This is the guide I am referring to https://www.ramtrucks.com/assets/bbg/pdf/2016/docs/ram/hdramcg.pdf . What are the codes in the GVWR column? It is a 2017 2500 Laramie with the Cummins and 6'4" bed.
- I will likely lift the truck using the AEV 3" DualSport suspension for offroad use with the camper, so will get a light camper. The AEV keeps the factory payload and tow limits. Any thoughts around this or concerns?
- Airbags. With the 2500 having the coils in the back versus the leaf springs, with a factory stance, or a 3" lift, are air bags recommended with a 1,200 - 1,600 pound camper?
- May remove the bed and go with a flat bed on the back and a four wheel camper. Any idea what the factory bed weighs so I can calculate out payload with camper + flatbed - factory bed?
- How is tire pressure properly determined based on payload and camper weight? Should I just run it at recommended PSI on truck door?
- Exhaust brake on the diesel. It's my daily driver, about 25 miles per day one way, so 50 miles per day. Do I leave the exhaust brake on auto, or what's the deal with that thing? Leave it off?
