BEFORE U DO ALL THIS, CHECK BATTERY, IF POSSIBLE USE ANOTHER VEHICLE BATTERY THAT U KNOW IS GOOD, NOT BY JUMPING..
Some things U can try from another fix dodge forum:
Some how the security/alarm got activated there's a security…
Some how the security/alarm got activated there's a security light #14 on the cluster it flashes and now I can't start my truck?
Mechanic's Assistant: Does the light flash, blink or stay solid? Have you tried to reset the security system?
It blinks, and I don't know how to reset it, manual doesn't say how to
Mechanic's Assistant: What is the model/year of your Dodge?
2003 dodge
ram 1500 with a 5.7 hemi
Mechanic's Assistant: Are you fixing your Ram 1500 yourself? What have you tried so far?
Yes can't afford to take it in. replaced my
battery because I thought it went bad
Mechanic's Assistant: Anything else you want the mechanic to know before I connect you?
Don't know what else to tell him
Share this conversation
Answered in 12 minutes by:
1/31/2019
Dodge Mechanic:
Ron
Hello and thank you for your question. My name is ***** ***** I am happy to assist you today. Sorry to hear you are having problems today. Give me just a moment to review your post, and I'll be right back with the help you need. The Web Site will prompt
a phone call , I'll let you know if it's needed.
Ask Your Own Dodge Question
ok, thank you
Dodge Mechanic:
Ron
On your 2003 Ram 1500, the alarm system can be disarmed two ways, one is to lock and unlock the driver's door with a factory key and the other way is with a key FOB by locking and unlocking the doors. Give this a try and let me know the results.
the truck isn't at my house I had to haved it towed to my girlfriends mechanics business loti tried both of those things already neither worked
Dodge Mechanic:
Ron
Okay, when you have access to it try the procedure I mentioned and if you have no problem with the lock it should disarm. If it does not and you are using a factory key, then you may have a problem with the lock cylinder and if that is the cases I have enclosed the steps in the link below to check this if that is the case.
https://www.dropbox.com/s/lu3fhgodzgwf0uv/cylinder lock Jan 31.pdf?dl=0
ok but i have some more info for you on how all of this started
Dodge Mechanic:
Ron
Sure, post it and let me have a look at it.
ok i was in a store shopping, came out unlocked my truck with the fob, door opened went to start it and nothing so i thought i had a dead battery because of the artic cold, went into walmart and bought a battery, put it in got in the truck to start it and nothing, thats when that red security light started flashing so i turned the key on to try and start it then several of the lights on my cluster started blinking simultaneaously about 5 or 6 times then they all went off and my head lights flashed on a couple of times to, tried to start it and nothing. thought you might need all of the info on what happened
Dodge Mechanic:
Ron
Okay, one other thing you can try because the battery was removed is to disconnect both battery cables and momentarily touch them togather to reset all module s and then reconnect them and then use your key to lock and unlock the door and then see if it will start.
ok how long should i hold them together? 5, 10, seconds?
Dodge Mechanic:
Ron
Yes, 5 to 10 seconds will do it.
ok thank you, ***** ***** let you know how it works out, thanks for your help
Your very welcome and thank you as well.
