Flo pro exhaust
Soto3389
MA
OK guys found it. Called Flo Pro. Tyler was super helpful. This is their new 4in exhaust with twister resonator. He informed me that in their R and D they only found it to slightly drone at 90kph(56 mph). Other than that no drone to speak of. Sounds so sick....Listen with headphones.
https://m.facebook.com/story.php?story_fbid=1718586978197779&id=141329485923544
Sent from my SAMSUNG-SM-G930A using Tapatalk
olyelr
Kewadin MI
Interesting. I would like to hear some more clips.
Odin
Arizona aka HELL
Hemi 6.4L
Looked it up on their site, basically looks like an exhaust with muffler delete and tiny resonator, or "twister" resonator, as they put it. Sounds cool, but not sure piping and a fancy resonator are worth the roughly $450-580 price range I'm seeing for something they designate as a "race application only". To each their own though. Not gonna knock anyone who gets this or has something similar. If rather dump and extra couple hundred on a full exhaust system with muffler if I were gonna spend the money.
Honestly, the drone isn't that bad with my Magna Flow muffler.
olyelr
Kewadin MI
Is your resonator removed?
pwjouster
South Florida
honestly havent heard any better then what ive done.
magnaflow muffler replacement and resonator delete dumping right after and above rear axle, pointed at the pavement.
beautiful drone all over in tow mode,just like any other SRT with pipes, nearly none in regular Drive. satisfies me intensely, coming from a charger hellcat.
pwjouster
South Florida
<a href="https://ibb.co/c6BbQ5r"><img src="https://i.ibb.co/R3FhcnD/IMG-0094.jpg" alt="IMG-0094" border="0"></a>
<a href="https://ibb.co/ykNR6P6"><img src="https://i.ibb.co/n1w07m7/IMG-0093.jpg" alt="IMG-0093" border="0"></a>
<a href="https://ibb.co/MBPZDcL"><img src="https://i.ibb.co/0sYmjC3/IMG-0092.jpg" alt="IMG-0092" border="0"></a>
you could pipe and tuck the exhaust under the right rear for a side exit and have zero drone im sure... i was looking for high clearance tuck exhaust
MBPZDcL
ykNR6P6
Odin
Arizona aka HELL
Hemi 6.4L
Sounds like exactly what I did
Sdreeser
Maryland
6.4 hemi
MBPZDcL
ykNR6P6
Hey did u just cut the pipe right in front of resonator? What size tip did you purchase to fit pipe?
pwjouster
South Florida
measure the outlet on the current res...i dont recall if it was a 3 or 4 inch diameter...
resonator was cut off right in front of itself. that inlet pipe to the resonator has some directional changes and bends.... must cut it in a specific spot to have a short tip pointed down and out without gassing the tire or other truck parts..
Sdreeser
Maryland
6.4 hemi
Ok thanks. Do u have much drone with that setup?
Odin
Arizona aka HELL
Hemi 6.4L
I know you're not asking me any of these questions, but my set up has very minimal drone if any at all.
My exhaust is also a high tuck with muffler only. Exhaust piping was routed over rear axel like the resonator piping was, however my exhaust tip basically dumps off at a 45 degree angle just over the rear axel. You can see the black tip I had put on if you look through the rear wheelwell.
Sdreeser
Maryland
6.4 hemi
Ok thanks guys for the info. I think I might look into a set up similar to that.
pwjouster
South Florida
i did not want to chop the resonator off and dump right over the axle because of the heat buildup under the truck. mine is dumped down and out behind the rear wheel where the exhaust fumes scavenge out from under the truck....i idle alot and that would be alot of heat under the bed..
