Flowmaster Super 44 Install
Stringbean2018
Round Rock, TX
Most of the shops in my area wanted anywhere from $250-350 for the muffler installed. I figured for that (or less) I could buy a welder, the muffler, and spare pipe.
I bought the Chicago Electric Flux-Core from Harbor Freight. First time welding so it wasn’t pretty, but I think it’ll be fairly effective.
I cut the tips off the stock muffler so I could keep it as a slip-on. 3” pipe slid directly into the inlet and I had to butt weld the stock tip there. On the back side, I had 2 1/2” pipe that slid straight into the Flowmaster, one tip was butt welded and the other will partially slide in before you weld. If you do this, I suggest cutting as close to the muffler as possible so you leave yourself room to work.
I was nervous because all of the bolt on exhausts have some kind of bend in them but I went ahead and lined it up and so it’s all straight and fits decent. I didn’t get to put a hanger on yet but it’s pretty firm in there. I’ll get some exhaust strap and run it.
All in all, very pleased with the process and outcome.
Hemi832
Houston
Damn, just had this same muffler installed in Pasadena for 150.
Hemi832
Houston
That was the muffler, labor, and the section of pipe he had to add. The shop is Lone Star Muffler on Richey in Pasadena.
abouttobeglue
That's impressive man, if i had a welder and a pipe bender I'd be changing exhaust at will!
Stringbean2018
Stringbean2018
Round Rock, TX
All in with welder, gear, materials, piping, and muffler put me at about $200. I got the welder on FB Marketplace for $70, almost brand new. Now my next project is to make a hot rod Radio Flyer for my son’s first birthday.
stevenmicheal
