Fluid leak after 18+ hours of being parked?
mands0807
South Tampa Bay Area
2018 Sport
The truck has been parked since 830ish last night, and around 530 this afternoon I noticed some drips about 6" off center towards the driver side. Wiped it up, and saw it drip some more. It looks pinkish in color. Checked the rad cap, rad is full, and I can see fluid in the reservoir. Looked from the top, and cannot see any visible leaks(yes I checked the plastic end tanks like in the other thread). Crawled underneath and found a couple of drips on the shroud. Have not taken anything off yet as it is getting dark here now. 20250315_184451.jpg20250315_185913.jpg
Dodge 1500 4X4
Rochester, NY
Check the weep hole underneath the water pump, also check radiator core plastic side tanks, been known to leak or split open, also check level in overflow tank, make sure you use OAT antifreeze & distilled water, you may need to have the cooling system pressurized to find leak.
mands0807
mands0807
2018 Sport
Had a chance to get under and pull the panel loose. Looks like it's time for a new radiator. Odd that it happened after the truck had been off and parked for 18+hours...*edit* truck is an '18 5.7 8hp70 2x4, and according to store.mopar.com with my vin, the second pic are the direct replacement radiators. Does this look correct?
Dredger
SE Ohio
The radiator you're showing states it's for a 3.0L V6 Turbo Diesel Engine. Your info states you have a 2018 Sport with the 5.7 engine. Check with Benny @AllMoparParts.com He's a forum vendor and I'm sure he can get you the correct radiator/info.
mands0807
mands0807
2018 Sport
I thought that I had my VIN in the store.mopar.com, seems I did not. This is what they are showing. RockAuto says the Denso shown in the radiator bubbles post does not fit the '18. Anyone have info on bproauto? And I'm guessing the price difference is the lower priced one expects a core return, and does not include a cap.
Ken226
Washington State
These what fits what websites are crap, and they are wrong more often than they are right. You'll have to take a little risk and order what you want.
Damn near everything i've ordered for my truck wouldn't fit if I went by these websites. Oddly, all the parts that wouldn't fit are working fine, years later.
Oreilly shows the same radiator part number fitting the following trucks:
Here is a 2016
Here it is for a 2018
Here it is for a 2009
So, order what youd like to put in your truck. I wouldn't hesitate for a minute to order that Denso from Rockauto. On the small chance it doesn't fit, you can send it back or resell it.
You could even run down to your local oReillys and pick one up. Then, if it don't fit you can take it right back to the store.
mands0807
mands0807
2018 Sport
That website offers free pickup from a Jeep Dodge Ram dealer ~30miles from me. That's why I was asking about the bproauto brand. If it's being offered by a dealership, the fitment should be fairly close to oem...one would hope.
*edit*, just looked at my messages and saw this...bproauto it is.
mands0807
mands0807
2018 Sport
@mands0807, how did your repair go?
Can I ask how much that bprauto radiator set you back?
I don't have the radiator yet, ordered from Benny. It was originally around $205 after shipping, but I got an email the next day saying the website had incorrect shipping dimensions, and the price went up $45, so $250 shipped. It would've been $260 plus tax and driving from Bradenton to St. Pete to pick it up.
mands0807
mands0807
2018 Sport
I'm having my mechanic install it, along with a PPE trans pan. I don't have the space, or time(single dad/2 teenage daughters) to do it myself, but my mechanic has a youtube channel, so I will post a link when it goes up.
EdGs
FL
Sounds good.
My problem is not having the ability to have someone else do it for me... lol.
Take these instructions to your mechanic,and make sure he levels the transmission not the truck.
Tell him these are the instructions that come with a "brand new " truck specific 8 speed,when bought from the dealer
mands0807
mands0807
2018 Sport
I already have that printed out, along with the instructions for Caulks thermal bypass. He has done a couple of ZF trans pans, but on BMWs(one was a PPE). The whole lifting the rear end on a Ram truck caught him off guard, but he understands why it needs to be done.
Cost me a few bucks to get those instructions :Big Laugh:
inception124
