I'm sure you have to bake them open like the headlights. I think @1500ram12 has opened a set or two before?
I'm guessing the cheap one you found doesn't have the same mounting pin style for the fog light itself?My lens is cracked and I just want to swap the lens and not the whole assembly. I found one used really cheap, the back mounting tabs are cracked, but the lens is perfect.
Do your current ones look something like this?
The housing itself is swappable if that pin matches.
How close are you to the metro Detroit area? I might have an unmolested setYup. Mine looks like that.
The one I found... they put screws in the pin. Probably trying to fix the wobble. I did the zip tie fix on mine and it worked great.
