You all should watch engineering explained's take on it;
How 85 Octane Fuel Can Destroy Your Engine And Void Your WarrantySubscribe to Engineering Explained for more videos! - https://goo.gl/VZstk7Recommended Books...
www.youtube.com
as well as project farms take on shell vpower nitro+ vs cheap
Is Shell V-Power Nitro+ better than cheap gasoline? Shell claims that it cleans better and contains 7 times the amount of detergents required. So, will She...
www.youtube.com
Several key points;
-Higher Octane = less knock... it does not necessarily mean more or less anti-wear/anti-sludge additives
Octane rating does not relate directly to the power output or the energy content of the fuel per unit mass or volume, but simply indicates gasoline's capability against compression.
-knock = when gas is pre-detonating in side the chamber due to exceeding compression + heat limits of the fuel
-pre-detonation/knock = bad news for engine
-Engines come with knock sensor to limit knock and damage, they do this by retarding power (less air+less gas = less pressure)
-Higher elevation = less air = less compression = less knock = lower octane offered for 'regular' in the state
-Those states that offer less than 87 octane, because the likely average elevation of the state meant that they could during the days of carburetors
--Colorodo
--Idaho
--Montana
--New Mexico
--Nevada
--South Dakota
--Utah
--Wyoming
-Ford 2021 says you engine is built to run on a minimum pump rating of 87, use of fuels below 87 could result in engine damage that will not be covered by vehicle warranty.
-Ford 2021 engine is likely turbo, plus modernized computer controlled fuel and air management, so elevation really does not matter as much anymore, which is why the 'requirement' to always have 87+
Conditions that are less likely to have knock;
-old carbureted car
-naturally aspirated
-high elevation
-eco-conscious driving
Conditions that will have a higher likelihood of knocking;
-Modern cars (meaning anything past 1987)
-turbo
-lower elevation
-petal to the metal / towing
In short,
-its about how you drive-
petal to the metal / towing = higher engine loads and pressures = higher likelihood of knocking = engine retarding power in the event of 85 octane.
If you don't tow or climb mountains or ram the throttle... odds are your not going to notice the difference.
That said
I had a 1998 Ranger, I went to one gas station and running on their 87 octane gas typically resulted in some weird sticky ticking noise from the engine.
Switching to shell's 87 made the noise go away.
Its was about the additives and the 'top-tier' standard rather than the octane.
Nowadays, I dont notice a difference between 92 or 87... unless I'm towing heavy uphill like I do when hauling firewood.
Which is why Ill always fill up with top tier with 87 for normal driving and 89+when towing no matter what state or elevation I'm in.
