For the towing newbies...
Sherman Bird
Houston, Texas
It should have come with one originally. My '17 has one, it stays in the little slot in the glove box that is, imagine this, the PERFECT size for just the owner's manual!
But I echo the statements, I have bought SO MANY used cars that just...don't have an owner's manual. Both from private party and dealers. I don't know if people just throw them away, or if dealers toss them out when they detail a car, or what...but there's a LOT of important info in those that apparently a wide swath of owners just don't care about.
People as a larger base, just do not read instructions as a general rule. Then, they get their proverbial buttock in a sling and cry foul! :)
TomB 1269
Schenectady NY
2019 Classic
Another trick for securing the rear of the car on a uhual is to run straps thru rim or to do a loop around the upper 1/3 of the tire with a froward pithc and pull the strap down over the rear similar fashion to the way the front works. I find trying to strap axle and other places not as easy as you'd think due to brake lines, etc. And lot of frames require the special keyed hooks to get a good bite.
62Blazer
Midwest
Eh I don't know.... .... every fifth wheel camper I've owned in the past 10 years has had a 65 mph speed rating from the factory. Even the larger fifth wheels. This is something that a lot of folks assume without actually taking the time to look at it.
I just double-checked eTrailer and every 15" or 16" trailer tire they offer is either a 75 mph or 81 mph rated tire. Goodyear has 15" trailer tires rated up to 87 mph. Carlisle also shows all of it's trailer tires at least 75 mph rated.
I know not that long ago it was common to see trailer tires only rated for 65 mph, but not nowadays. Can't imagine that a tire manufacturer would want to offer a tire only rated for only 65 mph when it's common to have speed limits greater than that on freeways. If anything the liability associated with this. Regardless of any warnings or rating they would post on the trailer tire you know somebody would have a wreck and try to sue the company even if they were running 90 mph on a 65 mph rated tire!
nlambert182
Huntsville, AL
Check RV tires. :)
Most are knock off brands with 65mph ratings. It has always been the very first thing that I change when I buy a trailer (fifth wheel or any RV trailer).
62Blazer
Midwest
Check RV tires. :)
Not sure what "RV" tires are.....have never heard of an RV specific tire, but guess that doesn't mean they don't exist?
I'm not saying that 65 mph rated trailer tires have never existed, but just not very common today. Again, not saying you are lying or anything but would be curios if you could link any sites to a normal size trailer rated tire (15" or larger rim size) currently produced that were only rated for 65 mph. Agree that a lot of people don't pay any attention to the load or speed ratings on a trailer tire and they should, and knowing which brands have a lower speed rating would be helpful.
Dan Topp
Jefferson Wisconsin
I have the weigh safe too real good engineering,but still wish I had a 3/4 ton or one ton my wife didn’t like how tall they were then oks me doing a 4” lift Great thread excellent work.E7B45192-A37F-4B86-848E-09B7086FD5A2.jpeg8CFD8448-EDC4-484D-96D2-940E837A159B.jpeg
nlambert182
Huntsville, AL
Sure. They're primarily an "ST" tire. Most RV manufacturers used them for decades. You can sometimes find that some are beginning to use Goodyear Endurance (Jayco) or Sailun (what I ran on all mine) but many still come with the cheap no-name tires. And most were rated for 65mph (at least up until 2021, when we got out of it).
Some of the most common that I've seen/experienced:
Trailer King
Mastertrack
Lionhart (was on my last fiver)
Westlake
Goodride
Arisun
Provider
National Roadmax
Most are very thin. 8-10 ply is pretty standard. I was able to fold the Lionhart tires in half when they were removed.
62Blazer
Midwest
Trailer King
Mastertrack
Westlake
Goodride
Arisun
Provider
National Roadmax
I looked up several of the brands listed above and all were either an L (75 mph) or M (81 mph) speed rating........
Agree these can all be cheap and generic tires with questionable durability and quality control, but the point on my comment was about the speed rating...and just hate seeing misinformation being spread around. If you can provide an actual link that shows a normal size trailer tire currently available that is only rated for 65 mph than post it!
nlambert182
Huntsville, AL
It looks like a lot of manufacturers are indeed increasing their speed ratings in the past few years. However, that does not mean that it isn't true. Tell you what..... drive down to your local RV store and look at the speed ratings on some of the tires on their fifth wheels (or travel trailers). You'll see what I mean.
There's no misinformation here. I've been towing fifth wheels for the better part of a decade, have gone through the same issues as every other rv'er. More than likely there are quite a few in here that know exactly what I am talking about.
"Tires on boat trailers have to be ST tires which stands for Special Tire. ST tires are designed specifically for boat, car and utility trailers. They are built to carry heavy loads on non-powered axles and are rated for a maximum speed of 65mph. Their stiff sidewalls help prevent your boat/trailer towing package from swaying. All ST tires feature materials and construction designed to meet the higher load requirements and demands trailer towing presents. ST tires have some of the highest load ratings. This is one of the reasons they are designated for use on trailers. Truck and automobile tires do not have to withstand the weight and stress that is put on trailer tires."
Special trailer tires have a maximum speed rating, just like passenger car and truck tires. Older tires have no special marking to designate a limit. Their maximum speed is 65 mph. Newer tires, those manufactured in 2015 and later, should have one of the following codes on the sidewall to show their rating:
(Note that I DID say that they may have changed that rating since I last had one...)
"Point of clarification. The Tire and Rim Association load formula used by the industry for ST-type tires is based on a 65 mph max operating speed. They even identified inflation increase and load capability reductions necessary to operate up to 75 mph. Neither P- nor LT-type tires have stated max speed associated with their load formula or calculation, as far as I can find. P-type do have the stated 1.10 “derating” of load capacity when used on a trailer or pickup."
Hope this helps.
