Jeff Krawczyk
For the guys that have the 2.5 fox coilovers, I just replaced my 6" strut spacer with them and after install I measured and I'm sitting a inch lower on driverside and a bit over a inch in passenger side...im assuming that I can fix that with buying a spanner wrench and adjusting the preload on the spring...if you have done it any idea what a full turn of the ring gives you in height...thanks
Pic of my mechanic installing them
