Frame swap
Micchi
Micchi
West Lawn, PA
5.2L
My personal opinion, good tires did more for me than fixing my limited slip diff. If you're going to spend aprox $300 on a LS diff, why not just bump it up to $600 and get yourself an eaton locker that will do wonders in the snow.
I was looking at the eaton true trac
Sent from my SM-G920P using Tapatalk
Micchi
Micchi
West Lawn, PA
5.2L
Got the rear axle taken apart. Don't know if I'm going any further than this.ac4d3fbf39101a4b8f03d08ee3c6db4e.jpgabe43654695b7bcc0e1f993477f7cf61.jpg2ae705ddf744a4eeb3cb9180b90909b7.jpg371ea4a4a7874fd51874e007e5ea8a87.jpg
crazykid1994
Replacing the seals? If you do could you put lictures
Micchi
Micchi
West Lawn, PA
5.2L
Yeah, planning on doing the seals in both axles once they come in. I'll get as many pics as I can
Micchi
Micchi
West Lawn, PA
5.2L
Made a small amount of progress the other day and disconnected the axle from the springs. ac5abc5c661db0c5d0509dd01717bdb2.jpgfe70b0eae0a73eef48df463e04d57792.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Springs are off, only had to cut 3 bolts. Just need to remove a couple of snapped bolts and finish sanding the rest of the frame and it'll be ready for paint.4e2a978ea60c23044f33fa41b91d1760.jpg
Micchi
Micchi
West Lawn, PA
5.2L
The pile of parts is growing. Finishing up sanding and hoping to paint the frame on Thursday.8eb483b74a25062f008af76cc736038b.jpgdee838bfe0aad62fc9cc3221c6c99a10.jpgd6d5539f197c63e83201127051e4b25e.jpg
crazykid1994
What did you spray it with
Micchi
Micchi
West Lawn, PA
5.2L
Pulled the seals out of the rear and installed the new ones. The factory seals had a lip that covered the end of the axle tube. I tapped that lip down with a screwdriver and hammer to loosen it up and then I was able to take a pry bar and easily remove it.
Also installed the backing plates and axle shafts. Once the leaf spring bushings arrive I'll be able to hang the axle back up and get it back on it's wheels.548bb7939c5e900979057a35f109753e.jpg8aeff5a976ea26c89f533b0c4e7f27ab.jpg2aefa9f6c27d545bbbac5d27cb439386.jpgab60a79cce0edaecfec29387a29a10d9.jpgf9ae298ba44714a62cf3a5346c32f9ec.jpgad8fb6806fdf6c980711c234d5b3fdf6.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Got my bushings today and mounted the springs and axle c5aa067993240cc9dafdfcd5894a8135.jpg2243419e7a5ffc4810fcb6c975b9124d.jpgb6a36c11a4bdd8dd192a67ddf47c4e4b.jpg
crazykid1994
Looking good. I can't wait to see it all back together. You should look into doing a shackle flip to soften the ride up in the rear. When I do mine I'm going to do one. I believe DOR is supposed to be one of the better ones
Micchi
Micchi
West Lawn, PA
5.2L
I had thought about it but don't have the extra money at the moment.
Gr8bawana
6.7 CTD
Did you replace the wheel bearings while you had the seals off? It take about 5 seconds to pull out the old bearings using a slide hammer. Good idea to replace the bearings since the operation is the same, just for piece of mind.
Micchi
Micchi
West Lawn, PA
5.2L
I did not but there is no play in the axles and there was hardly any wear on the shafts.
