friends an idiot!!!
johnny$kin$
cummins 6.7
so i was wiring up my subs out at my buddies shop an servicing the batteries an he was ina hurry to leave an roll into town so he jumped in to help. well he forgot to hook up the power conection that leads to the intercooler sensors off the drivers side of the head when i drove home an knew somethingwas wrong. so this morning i found it an hooked it up. when i started it the turbo was winding up pretty hard at idle then when i turned the jake on the turbo really started to scream so i killed it. then went to start it again later an it was dead p2509 popped on my code reader, the 30 amp tow fuse was blown an idk if that effects the jake or anything. im just wondering if drivin 13 miles without the intercooler sensors hooked up would harm my turbo or affect something major.........? stock 6.7
WhiteExpress
Midland, TX
A quick google search tells to check your battery terminals. Since they were also serviced at this time, I'd double check em.
They make mention of a fender ground that can be finiky as well.
Best of luck!
