Front Axle U-Joint Replacement Help!
U&A
2016 3500 SRW
6.4 HEMI
392,
Thanks for helping.
Sent while firmly grasping my redline lubed RAM [emoji231]
Erikk
Erikk
West TX
Thanks for the advice 392!
Erikk
Erikk
West TX
So I had a mechanic friend do the joint replacement and he said the axle came right out and slid right back in just like other axle designs. He did mention that the passenger side axle on this design is easier than the older solid axle because the shaft is so much shorter so it’s easier to maneuver back into the seal and collar splines. CAD plate was never removed and I tested the 4x4 and it operates perfect.
Zack02
Thanks man!
