m_durham_226
- Jan 21, 2017
- 3
- 7
- 2015
- Hemi 5.7
_________
Is there any more info on these. Will it bolt up to an 18 and does it still require the frame cut? Figure I'll gather as much information as I can before I spend another 1000 and scrap the no cut 4 inch pro kit lift and install the zone 6 inch front
When I was at 3 inches I didnt need it. The angles are terrible at 4 so I need to drop the dif down. I was just going to go with a zone front lift to match the rear but if I could save cutting and the money of the front lift I would be interested in the bracket. Just didnt know if the tabs still had to be cut with it and if it would fit the 18. I'm still in the air but just want to do it before winterYou probably dont need it on an 18.
Frame dosnt get cut just the contol arm cross bracket
Yes that was the change in 2012.FWIW my 2013 has 5100s at 2.8 and my cv angles aren't bad at all. I have no vibration in 4wd either. I wonder if 2012+ axles sit lower?
