Front diff oil
R
Rickyd31
Montreal
The Owner's Manual says to use "MOPAR GL-5 Synthetic Axle Lubricant SAE 75W85".
The MOPAR part is irrelevant, GL-5 and the weight is what is important so you are good to go. Free is good.
I just did mine with Redline 75w90 GL-5.
Yeah probably the same company that makes the “honda” and “mopar” oil.
I figured it shouldnt be a problem. I rather ask and be safe. Couple $$ for the right oil vs a $$$$$ for a new diff cause i used the wrong oil lol.
mdc1990zr1
Conshohocken, PA
Like grizzstang said, GL-5 and correct weight is what’s important, not the name on the bottle. If you’re worried about the quality, change it more often. I try to change at 30K intervals myself.
R
Rickyd31
Montreal
Quality isn't a problem. Ive seen that oil do 100000km (70000 miles) and not change color.
Should the rear diff be replaced at 30k as well ???
It's never a bad idea to change the driveline fluids early,including the transfer case.
mdc1990zr1
Conshohocken, PA
All of my 2500 and 3500 trucks suggest a 30K rear differential oil change. I believe it also suggests oil and filter change at 4K for severe duty, which I am. As the vehicle ages, and I frequently go over 250K miles, I do some 3k mile oil change intervals. Front differential doesn't turn like the rear unless specifically engaged, so I guess you could go a little longer. The transfer case is always turning so I would do that on a shorter interval like Wild One suggested.
Burla
2010 Hemi Reg Cab 4x4
Diffs and Brake fluid are two items that get the poorest maintenance. If not replaced it should be inspected because you have breather lines that can have moisture intrusion. Many times someone will change diff fluid and it will have that milkshake look. Take a little out of top hole and smell it and put it in clear glass if you don't feel like changing it.
R
Rickyd31
Montreal
Oh i know. I do this as a trade. Expect i work at a honda dealer.
Transmission is in the top too. Ive fixed many judders by simply just flushing the contaminated fluid out.
Lloyd33
Army
Ely, Minnesota
8.0L V10
Just to add one thing to this..
The owner's manual doesn't know where you live. The oil viscosity that you use should really be selected based on the temperatures that your vehicle will operate in, just like engine oil.
joesstripclub
Kansas City, MO
2021 2500 PW
My rear diff has been much dirtier when I've changed it compared to the front, especially if you have limited slip on a 1500. Those are supposed to get friction modifier though so double check if the honda fluid has that if you use it in the rear diff.
QwikKota
5.7L
3k mile oil changes with synthetic? That's throwing money away.
mdc1990zr1
Conshohocken, PA
Like I said, my trucks are alway loaded, maybe overloaded sometimes. They never get a break. i also, never ever opened up an engine and when I get rid of the trucks its generally because of rust, not because they become oil pumpers.
DUCKY1090
