Front Differential Crack
osprey92
I rolled under my new 2017 truck with 5000 mi to perform the first oil change and was flabbergasted to see what appears to be a casting crack on the front transfer case. Anyone seen this before? No fluid leak. I just am beyond belief this transfer case was installed.
Tdjma
Truly think it's a casting mark
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Either way, get it documented NOW, so they can't accuse you of doing something that caused it later if it becomes problematic.
repo4sale
6.7diesel
Demand in writing a new case be delivered for replacement, and/fully paid truck rental
Sent from my Z988 using Tapatalk
O
osprey92
Not familiar with a casting mark leaving a 1/16" gap narrowing to about 1/32". Also on the support bracket and back it spiders off into narrow fractures.
Tdjma
I can't tell from the picture I would def take it in to be checked out
grizzstang
Calgary, Alberta Canada
I think it is a casting mark too. It would not impress me either and I would point it out the next time you are at the dealer in case it does start leaking. Ultimately a dealer won't do anything about that until it does leak if it ever does.
O
osprey92
After the shock wore off I reached out to Ramcares. Just mad now...
stimpy433
IOWA
Looks like the casting marks we use to see on the gear boxes we built for heavy equipment.
Ratket
Arizona-
Casting mark or not- get it documented.
ExpressRules
Southern New Jersey
2019 Big Horn Crew Cab
That's right, jump to conclusions and make demands before showing it to the dealer. And also he should storm into the service department yelling insults at the service manager prior to saying why he is concerned. :waytogo:
huntergreen
Marine Corps Navy Badge
Just have it checked.
stimpy433
IOWA
Didn't you read that part in the owner's manual.... page 345. :crazy:
O
osprey92
You're all correct, front differential. After years of multiple blows to the brain, not all the neurons fire in the collective memory. :)
CMSBusDriver
