Front end clunk
tmac
I just installed the 3 inch BDS lift into my truck a few days ago. Since the lift I noticed I have a front end clunk when going over bumps. It doesn't really make the noise if I go over a bump, like a speed bump, but when my right fron.t tire hits it before my left there is a notice clunk. I rechecked eventing and all parts are tight and show no si gns of anything hitting. Any ideas?
T
tmac
Yes it came with drop bracket for the trackbar.
schroederMP
Indiana
Cummins
Check that and the trac bar...I thought I had mine tight, noooope. A breaker bar and pull till you fart. Should do it.
quietpeen
2021 TRX
Hellcat
be carefull that could turn into a pull till you **** your pants :lol:
T
tmac
I have tightened the track bar and drop bracket as tight add I can get them with a large breaker bar. Clunk its still there. Any more ideas?
T
tmac
They are tight, truck is brand new.
Catchin Zs
Wilmington, NC
See if it makes the sound when you hit the brake while going over a bump. If so, your brake clips are loose.
CMSBusDriver
