gto64gto
My son in law has a 2017 Ram 1500 4 wheel drive. I put a 3 inch lift on the front to level the truck about 6 months ago. It was a round puck type that attached to the upper strut with 3 bolts. It was a easy job. About a month ago, his truck developed a squeak at the left front. He took it to the dealer and they replaced the left strut. The squeak stopped. Last week , the right front developed the same squeak. He took it back and the dealer wouldn't fix it. He said it was the lift kit. I went by and talked with the service manager. We are pretty good friends. He said the problem wasn't the strut, it was the lift kit puck rubbing underneath the strut tower. He said he has run across this a couple of times with the 2 inch kit the dealer installs. He said you can loosen the 3 strut bolts and reseat it and it will stop it. I haven't had time to do this yet. Has anyone run across this and if so, what did you do? I torqued the 3 nuts to recommended specs. The truck has around 10,000 miles and it just seems to me that a strut shouldn't go bad that soon. I can see no leaks on the right front. Thanks.
