Front grille replacement 2016 missing mounting brackets need help
Gator 62
Alachua fl.
ordered a front grille for my 2016 dodge ram crew cab Laramie. when it arrived it was missing mounting brackets. Unfortunately the company will not respond
and turned out to be a bad company. Now i have no way to mount the new grille .HELP!!!! DO NOT ORDER FROM WILDROCK4X4 OR OFFROAD ROCK. any suggestion's on how i can make this work ?
Phirebeard
NW PA
Need more info for sure. Depending on the grill, you may be able to transfer things from the factory grill to the new one. I was able to transfer the support pieces into my new grill.
shaunnz
