front lower sway bar nut
Ramsport14
Installing a 1.5 level kit on my 2014 2wd Ram. Trying to remove my front sway bar nut that pockets up into the lower control arm. Broke it free but now it just spins and I have no way to grab the bolt to keep from spinning. No clue where to go from here.
The other side I just removed the top nut and bushing the sway bar and will allow to drop down with the lower control arm. But I still have to deal with the passenger side.
Any advise would be appreciated big time. Thanks
Shaunm59
conroe tx
5.7 of make her wet liters
Most likely will have to reach in there and weld the nut back on. I had 3 break loose when I put my ram runner system on. Needless to say, I no longer run a front sway bar.
