Front spring instructions help
sixbangr
Texarkana, Texas
2015 rcsb Sport
Wanted to see how to do the 2/4 drop before I bought it. I can only find info for the rear. I would like to see what is involved in doing the front springs. Truck is 2015 reg cab RT. thanks
pimpinHEMI
Take the nut off the upper ball joint, sway bar and steering end link. Remove shock. Drop lower control arm and remove spring. Then replace with new stuff
sixbangr
sixbangr
Texarkana, Texas
2015 rcsb Sport
Well it can't be any simpler than that, thanks
pimpinHEMI
Its really not that bad at all. I just did it tuesday. Instructions came with the kit. I skipped over the part where it said to remove the rotor and speed sensor. My rotor was stuck on so i just skipped over it. Didnt need to do it anyway
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
You'll like the 2/4 on a RC :D
