Front suspension
michael thompson
San Angelo, Texas
I have a new to me 2014 ram 1500 bighorn. I’ve noticed a clunking sound coming from the left front. What could cause this? Possibly the sway bar bushings or links? Any help would be appreciated!
Ratket
Arizona-
Check the Upper control arm bolts, Also the top strut mounts can move but they typically squeak-
easy way to check is park the truck and have someone sit in it and turn the wheels left to right and watch one side through multiple rotations for anything moving that shouldn’t be then check the other side.
BenWade
Houston
Could be that but most likely the upper control arm. Just like with the exhaust manifold bolts the control arms are the next most common problem. They're just cheap and wear out fast
Sent from my SM-G965U using Tapatalk
Elevated 2013
Huntley, IL
When do you hear the clunking? Over bumps? Only when turning a certain direction?
tidefan1967
Summerville, South Carolina
Check your hood bumpers. I know it sounds like that can't be the problem but I had a very similar problem early last year that sounded like a clunk when going over bumps, turning in the driveway, etc that sounded like it was coming from the front suspension. I screwed both the hood bumpers out a couple turns and it stopped completely and hasn't done it since. I would have sworn on a stack of bibles that it was a loose shock or cab mount bolt but it wasn't. It only takes a minute to try and if all else has failed you never know.
RamCares
n/a
n/a
We certainly understand why this would be concerning, Michael. If you are not able to determine a solution based on the suggestions provided here, we kindly recommend following up with your local Ram dealer for further assistance. Our team is just a PM away if you are in need of any extra support for that process.
Mark
RamCares
stevenmicheal
