Front U joint replacement 2015 ram 4x4
Activate
The Netherlands
2015 and 1998
360 and 410 with SC
Hello,
I have play in the front U joint from my RAM 1500 4x4 sport.
I have looked at Rockauto and Summit but can not find the U joint?
Wich one do I need?
Thanks and greetings,
Erik.
NOV87
PNW
I would get the part number from a dealer and cross-eference it to what on-line stores have. This is one I bought locally for the rear shaft for 2014 1500 4x4. Both axle and transfer case ends. Please, ignore the drill bit :)
Hemi395
Cape Cod MA
Are they even replaceable on the front driveshaft of the 1500s?
Phirebeard
NW PA
I'm not finding just the u joint either. You may have to replace the whole driveshaft.
DILLIGAF
Canada
I replaced mine when I did my Gen 3 front diff swap.
I Just pull it and went to the parts store. They matched it up for me, but I dont remember the # unfortunately but it was a standard MOOG one.
My spare front driveshaft is under 4 feet of snow, So I cant get the# for you... lol...
Whatever you do dont waste your money replacing the whole thing... lol..
Victor Brill
Kansas City
Jumping on this thread instead of making my own. Looking to replace my U-Joints on a 2011 Ram 1500. Curious what you ended up going with OP?
Looking on Rockauto and they have a lot of options. I see the Moog 331 that is listed above and will probably go with that. My question would be, do people prefer the Moog or Dana Spicer? Also, there are a ton of Heavy Duty options that aren't much more expsnsive but wondering if they would be worth it( I don't tow/haul/off-road that often.)
Any help would be appreciated.
Livinalittle
Ontario
2013 Sport, 6 speed, 4x4, 3.92
I just replaced the whole front driveshaft. I ordered from Partsavatar in Canada for about $250.
PdPuNOme
Jersey
No one have the same problem?
I am. My original from my 15 ram has a sticky/hard spot in the joint, so got a donor from a 19 classic and has the same exact bad spot in the joint as the 15, go figure... this is very common for the front driveshaft from all the digging I have done. Only real info I can find is there are two versions one for the 6 speed trans at 33" total length and another for the 8 speed (dial shifter) at 33 3/4" length. Nothing on the u joint. Either way I would only go with Spicer brand. I will follow up should I come across the correct p# for the ujoint.
Chaga
New Brunswick
Anyone have luck finding a u joint? Or did you have to replace the whole shaft?
Hemi395
Cape Cod MA
I have a feeling it's a common u joint, it's just finding out what part number it is. I'm sure they wanted to make it so we would have to buy the whole drive shaft but the u joints have to come from somewhere
Chaga
New Brunswick
Hopefully someone here has some info on what u joint.
Panarama
Florida Panhandle
Wow, no one here has ujoint part numbers memorized?
Back in the day, I knew the what those were- across the board of manufacturers. Which ones were stronger, etc...
It was cheaper to replace ujoints than diffs, trans, etc.
Mwilson
Utah
Hello,
Wich one do I need?
Erik.
Hey, don’t know if you fixed the issue but I figured it out. The front u-joint is replaceable. However, the manufacturer designed it so the u joint is not easily replaced. The perfect fit for replacement is a Spicer 1310 u joint.
The clips are sunk into the yoke (dimpled), meaning that they cannot be pulled with a pair of pliers. I had to drill out the clips so I could get to the u joint. Once removed and replaced inside the yoke, I had to use a punch to push the metal on top of the u joint caps so they would not fall out.
Since they aren’t really meant to be replaced, my advice is to buy a front driveshaft from rock auto and save yourself the headache.
DILLIGAF
Canada
No one in their right mind would pay for a new drive shaft when all it takes its a 20$ U-joint.
If you think thats a headache dont do gear swaps... lol...
