Front wheel hub and bearing assembly question
Derekk
California
My right front wheel bearing has gone out on my 2015 Ram 1500 bighorn
Im going to replace both front hub assembles Does anyone know if there is a left and right hub on the 2015? When I had to replace them on my 04 Ram I seem to recall there was a left and right hub. I think it had to do with where the ABS harness attached. I can't find any that are designated left or right for the 2015
Administrator
A quick look on RockAuto shows only one part for the front wheel bearing assembly, nothing designating a left or right version.
Jeepwalker
WI
2012 Reg Cab, 4x4
Good luck with the proj.
Edit: Avoid buying 'cheap' ...if you plan to hang onto it for a while.
