I dont believe in additives, especially oil additives. I believe the motor oil geek has explained how additives can conflict with oil additive packages in your chosen motor oil.
For me, penzoil ultra platinum 5w30 or mobil 1 ,
I can of seafoam in crank before oil change, seams to clean and allows for better oil drain..
I do put a full bottle of seafoam In gas tank then fill it with 89 octane fuel whenever I change my oil. So I use two bottles of seafoam on every oil change. I change oil every 3-4k miles.
I believe high quality full synthetic oils have all rhe additives our motors need. For me, changing oil frequently is the best way to keep our engines clean and protected.
I put 335k miles on my first hemi, and I believe if I had bought it with less miles on it, 85k in 2016, I could have gotten even more miles.
I am convinced the seafoam flush is beneficial, it might not have done much, but at least I believe it helps clean out motor and makes oil changes more complete. I drain oil for like 30 minutes before I fill motor.
I filter my used oil through a cheese clothe and don't find any chunks or particles.
Just switched to pup, so after 2nd oil change I am planning to.send out a oil sample.
Ypu can never get all old oil out so first change to new oil is mixed with a little old oil.
So I will change oil again In 3k miles and send sample oil out for analysis. Motor is new, put remanufactured hemi in this past June So i don't expect to find much wear metals, but who knows. Also I am a little disappointed with he shop that swapped my motor, cost.me.$9k, and they just cheesed off on some small things. Oil pan bolts where original and rusted, some not tight and one broken off in block.
Stripped two bolts on oil pan braket of cover on back side.
I need to check all the block ground points as I suspect they might have skipped some.
I am little annoyed that they did not even talk to me about pil pump.water pump etc. I would have liked to have new oil pump and water pump installed as well as a new oil pan, gadgets etc. Not sure what they replaced or.not..
