superjoe83
I called two different dealerships and they both told me that the system does detect if the filter is dirty regardless of miles or hours on the filters.
I would like an explanation on how the truck can sense filter restriction, because the only pressure sensor in the entire fuel system is on the high pressure fuel rail, and yes, if the filter gets restricted to the point of starving the high pressure fuel pump you will get low fuel rail pressure codes which will turn on the check engine light.
I don't see anything that the ECM could use to determine filter life other than mileage, time, and gallons used
The fuel delivery system is very simple on these trucks, you have the in tank lift pump, which is turned on by the fuel pump relay, controlled by the ECM, there is no feedback for the ECM for motor current or anything else that could be used to estimate filter restriction, the rear filter, has a water in fuel sensor, and a fuel heater, the front filter housing also has a fuel heater, and a water in fuel sensor, thats it.
