Fuel pump gone bad?
goodtodoo
1996 indy pace truck
Parked the truck last night, this morning no start. WTF. What should I start checking?
Shadow_Death
Killeen, Tx
Fuses, spark, fuel pressure.
Probably a lot more that others will chime in with. The main one is fuses, make sure that they are all good before trying to diagnose anything else.
Also a better description of what happens when you try to start it will help too. :)
Edit: Oh and if you have a check engine light on the codes would make things easier too.
G
goodtodoo
Ya the engine just cranks over and no start. No check engine light. The truck was running good, now it won,t start.
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
Could be a lot of things. Fuel pressure is easy to check if you've got a tester. Should hit 45+/- with key on, engine off.
Crank position sensor could be bad as well. If it fails, you won't get any fuel pressure because the computer uses it to determine when to reactivate the fuel pump when the engine cranks over as well as keep the fuel pump running while the engine is running.
So, if you've got no fuel pressure, it isn't necessarily the fuel pump. However, the fuel pump will prime irregardless of crank sensor condition. When you turn the power on, try and listen for the fuel pump priming. Our fuel pumps are pretty easy to hear. If you can't hear it prime and you've got no fuel pressure, the fuel pump is probably a pretty safe bet.
G
goodtodoo
Ok, thanks ill try that.
