Fuel Pump
fadetoblack188
so my fuel sender stopped working on my ram 1500. 2014. Anything less then half a tank it reads empty.
So if i am going through the trouble of dropping the tank i guess i should just put a new fuel pump assembly in.
Mopar looks to be 300 bucks. Any of the aftermarket brands reliable? that are little cheaper
Kid's HEMI! !!
I ran mine like that for 3 years finally replaced it a few months ago with mopar one , I did the whole pump
jws123
nj
I am normally a fan of aftermarket cause im to dam cheap to use mopar but 5 months with a $130 aftermarket one it failed again had to do it all over got the mopar one no issues sucks but this is 1 part ya want to use oem.
EdGs
FL
My 2015's fuel sender went goofy also, it will occasionally go to zero, trip the CEL, etc.
Bought a replacement pump assembly by Delphi, hopefully it is a decent replacement.
The pump itself is working, so going to hold off changing as long as possible. Hope the Delphi lasts.
Marshalljud
I had the same issue and this was my issue. I replaced with a Delphi pump in November and haven’t had any problems yet :)FCA0647F-42F7-44AF-B7C8-EE537717F7B1.jpeg
