Sharon
Hi Y'all!
I made it to Tennessee in the new truck. Only had an atv for a payload, no towing this trip, but the Cummins purred along. The night before departure, I went out to check air in the tires and thought I'd torque the wheels as some of you suggested, since I had just had tires installed about 200 miles ago. Couple loose ones, but most were tight. I should have backed them off first to make sure the installer had torqued them correctly, but with a long trip ahead, I thought it best to leave it alone.
Anyway, the sob put the white lettering inside... didn't ask and I didn't notice until I got home, 3 hours away. When I popped off the lug cover, I found one missing lug nut on two tires! I guess 1200 bucks for tires wasn't enough for him to be arsed to call me or just replace them.
Preamble out of the way. I'm curious first of all what the fuel mileage thingy is called so I know what to refer to it as. And second, it isn't very accurate. Is that the way they are or does it need to be calibrated? I double checked the odometer against the mile markers. and it was spot on in a ten mile stretch. I'll check going home over longer distance for better accuracy, but until then... I thought I was doing really well with my driving based on the indicator thingy. I was getting 21 mpg or better. I even reset it on occasion, always getting similar results. That includes infrequent stops and starts off the highway. Considering a 34 gallon tank, I should almost have enough fuel to go non-stop to my destination, yet I had to refuel way too soon. Topped up with 32 gallons. Calculated about 16 mpg.
So, what's the scoop?
