scottytewshoes
Hello there!
My name is Scott and I am the proud owner of a 1989 Dodge Ramcharger equipped with the 5.9L 360 V8. I've joined the forum because I am teaching myself vehicle maintenance and basic mechanics right now. It may be true that, "you cant teach an old dog new tricks", but Holy Shi* sometimes those old tricks save you $$$$!
Anyway, I've got a puzzle and I'm sure one of you knows how to solve it. I have what seems to be. combination an electrical & fuel problem. Currently i can't get the old girl running. I seem to be getting everything but fuel. There IS Power at the sending unit but the pump isn't turning on for more than a minute at a time. My cap, rotor, wires, and plugs were replaced two years ago & my battery is 9mo. old - i checked them all recently; no problems stood out. The engine turns over but there's no combustion. For a while there i had something draining the battery CRAZY fast. Multimeter measured -.01v per second! I've been cleaning wires and harnesses and something i touched stopped the weird battery drain apparently. Ive got a batt charger/booster/starter that I use to try to fire up the engine if its cold or early. I dont think its the batt cold cranking amps. My alternator has been inspected and tested at 2 diff shops (since im paranoid) and passed with normal results.i cut an access hole in the back of the ramcharger so that i could reolace those fittings and swap the fuel pump. Also changed the fuel filter. Treated the gas, oil, steering, radiator, atf and refreshed the coolant so all my fluids are good. Got a new air filter, fuel filter (translucent so i can see fuel flow through it at the sending unit, i kept the normal filter below seat as well), oil filter. Adjusted all my belts to proper tension. Cleaned out the air intake/parts of the tbi. I've been cleaning all the harnesses and putting grease on the connections and idk what else to do!!!!!
My Plan (for now):
Install universal pump in-line to bypass my normal fuel system haha. Please Help!
Sent from my SM-G935P using Tapatalk
My Plan (for now):
