WillB
- Jan 9, 2018
- 34
- 22
- Location
- Innisfil, Ontario
- 2017
- 5.7 Hemi
is anyone using a Fumoto valve on their Hemi Rams?
Thanks. Im guessing its the same size as a Fumoto?Not a fumoto specifically. I’ve got a stainless ball valve to drain my oil. Summit racing. Matched with my filter relocate makes maintenance a breeze.
Mine is going on this weekend. It came with the plastic lock. I bought the valve with the hose nipple output so I can cram a hose on it & drain right into a container. Then I'll put a short piece of plugged hose on for peace of mind.Been using Fumoto valves on my vehicles for years. Best DIY oil change system going.
Previously used an oil extraction pump, but the valve is so much easier.
Buy the little plastic lever lock for peace of mind.
F106 (14mm-1.5) for both Hemi and V-6.
That’s hopefully being caught by the filter. Could also run a filter magnetDrain plug is magnetic, you’re going to allow your cam/roller slivers to cycle through the engine...
I checked mine before switching to Fumoto. The stock plug is not magnetic on 2015's. It's great being able to flip the valve with only crawling under the front (and change filter) rather than having to jack up some to get under the runners from the side.
I have a fumoto valve on my ram since first oil change (2016). Have one on my wife’s Subaru for about 5 yrs. Had one on my old F150 as well. Have used my truck off roading and never had an issue.
