Fun with LEDs!
Docwagon1776
Midwest
Nice work, it looks good. As some others have said, it would be illegal in Indiana as well, though, unless you are a volunteer firefighter on your way to an emergency.
WhiteRam
Dallas, TX
2012 2500 CCLB
6.7 CTD
Super *******.
Sent from my LG-P999 using Tapatalk 2
the codes
Houston, Tx
Magnum 5.2
looks great, very clean work.
I like the blue, but like everyone says, more of a show it off in the parking lot thing then something you can drive around with.
still cool, id do it if i had a 4th gen lol
king99
Lakewood, IL
I've been wanting to do this on my lower valance like you mentioned. What size bulbs did you use? 5mm, 3mm? Electronics are not my thing but I refuse to be defeated by them. Could you list the parts you used? Bulbs, resistors etc etc. I'm confident that i can do the install but not so confident that I will get all of the parts ordered correctly so that it all works properly. Is your power coming straight from battery? In-line fuse? Gotta dumb it down for me a bit. Still on an electronic learning curve.
blackout11
alpharetts GA
2011 R/T
do it the way i did mine just order prewired led's that way all you need to do is connect the pos and neg's together then hook them to a switch
LEDs - underbody kits, cathodes, flexible LED strips, dome lights
Super Bright Pre-wired LEDs
go with 5mm
i also put 28 in each scoop
Miami Son
Miami Son
Banned
Port St. Lucie, FL
2012 Ram 1500 Sport Crew Cab
Just my opinion, but 28 per side seems like overkill to me. I just wanted some accent lighting, not a supplemental light source. At hood height I could see those being a real annoyance to a driver in front of you. Looks cool, though.
blackout11
alpharetts GA
2011 R/T
oh lol its just for shows lol i dont drive around with them on
stevenmicheal
