garage heaters
16Hemi
16Hemi
Northern Ohio
thanks for the good information. i will have to look into the insulation part of it first before i worry too much about heating it.
0rion
Ohio
5.9 cummins
I just put this in over the winter. Love it. I drink alot of beer in the garage during the winter and this easily keeps it at 70 in there. Has 5k Watt and 7500 watt settings but never have to run on the 7500 setting. My garage is well insulated which helps a ton.MVIMG_20190330_230428.jpg
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
I just use a propane torpedo heater when it's that cold out. It won't get it shorts and tee shirt warm but it does get it warm enough to get things done.
T_Unit114
US
I have an 80,000btu kerosene torpedo heater. I can keep my 24x24 garage at 60 degrees with an insulated ceiling and a ****** fiberglass door with holes in it [emoji23]
Sent from my Pixel 3 using Tapatalk
modstang
Kansas
5.7 Laramie
Good morning to all on the site!
I have a 30’X40’x12’ attached garage up in the Northern lower peninsula of Michigan. I installed hydronic heat tubing in the floor with 3” of foam under that. I used (4) 300ft. runs of 3/4” pex tubing in the floor. It keeps the room as warm as I want it. You want to make sure you use tubing with an oxygenated barrier for heat BUT NOT for potable water. I also used an antifreeze specifically designed for hydronic heating incase I lose power to our cabin.
Larry in East China Mi
I’m looking to do another garage next year, did you plumb the system yourself?
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
I have a three car garage and I use an electric 220v heater mounted to the ceiling. Its runs up to 4000btu but as its wired its now at 2000btu. If its 35 out side I get get the garage to 75 in about one hour. Had it for about five years now, best $175 I every spent for the garage.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
You guys with propane torpedos have any issues with fumes or do the cats filter out enough for a sealed environment?
