Gauge Pod
NDanecker
Earth
Has anyone added a gauge pod (single, dual or more) to their 5th gen Ram? Looking for a single pod to sit between grab handle and dash cluster that sits on the dash or if I must replace the grab handle with a gauge pod cluster. What mfg have you used? Pics if you can.
yakalong
KC
What gauges are you looking to add?
runamuck
Air Force
dfw
6.7 dsl
scroll thru the CIC and you will come across just about every gauge you could need. I use one when towing that has all the temps and pressures
Moparfanatic21
U.S. Marine Vet - 0321, Now a Doctor...of Vehicles
CIC?
As to OP look into getting someone to 3D scan your truck and 3D print a pod. I talked to someone about it for my 2nd gen to get a custom Switch pros panel mount and they quoted me about $80-$120 depending on where I want to mount it which I have yet to figure out
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
CIC?
Pretty sure he meant DIC, not CIC. :cheers:
