Gear install help
bloombloom88
Plano, Texas
In a few days I'm going to try and tackle installing my 3.92s on my day off at work. I'm going to be limited to a few hours of using a bay and lift, so if anybody has done this themselves I will appreciate any input you can give me to speed up the process.
I really need a step by step of what to do and in what order. I have a open diff so that should make it a little easier.
Is the pinion gear bearing pressed on?
What's the crush sleeve and how do I know when it's tight enough?
I have too many questions that need answers so tell me what you know!
Etroze86
Grand Forks ND
Ask someone at a shop that has access to Alldata to print you off step by step instructions.
Jpeyatt
Its pretty self explanatory once you have it in front of you. The tricky part is shimming it which I wouldn't recommend do yourself... If not shimmed correctly, you'll be wishing you paid someone to do it. If you shoot me a PM, I can pull it up on alldata for you Monday and fax it to you. Even then, it won't give you the shim info because that's all based off of each vehicle and how much play it has.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
TylerB
FL
Not trying to be an ass, but from your questions I would say this is a job for a professional.
BlackRamHemi
Edmonton Alberta Canada
x2!!!
I've always done all my own work on my vehicles for 30+ years,
but two things I leave to the professionals are Gear Swaps and window tint.
codyjc2
6.7L Cummins
The shims will be determined by backlash. To check backlash you need gear paint to see if the pinion teeth are meshing properly with the ring teeth. If not then you have to break it back down and add a shim. Repeat until you have the proper gear mesh. You should be able to find more specific instructions online.
bloombloom88
bloombloom88
Plano, Texas
Thanks guys, if I had a full day to do this in the shop I would, but a few hours just isn't enough time. Ill have a tech do it one day
moparman
Woonsocket, RI
2016 Ram 2500
The 9.25 is not rocket science like everybody makes it out to be. Granted the adjustments can be a little tricky, its not all that bad. However, you do need a few specific tools to do the job correctly.
Do you have:
1) Hydraulic press
2) Dial indicator with magnetic base
3)Tool to adjust collars for backlash through the axle tube or access to a
welder to build your own
4) Cutoff wheel to remove old bearings
5) Basic hand tools and impact gun
If you answer yes to all the above, i will write a diy for the install.
Sent from my Galaxy S3 using Tapatalk 2
moparman
Woonsocket, RI
2016 Ram 2500
The adjusting tool is a chrysler part. I made my own for free but you can find them on ebay for around $100. Once i have a few minutes ill write the diy
bloombloom88
bloombloom88
Plano, Texas
I'm sure I can find at least 1 in the shop, it is a dodge dealership
Immerge
