Gear Pattern check
DILLIGAF
Canadian Forces
Canada
Hey guys,
This is my first diff, just want to make sure these look good
Fast69Mopar
Hey guys,
Looks good based on the pics. I'd run it any day. What do you have your backlash set at?
Also, what is your pinion torque-to-rotate?
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Also, what is your opinion torque-to-rotate?
I set it at .0006. and 20 in-lb
Im worried I was to close to the edge of the gears. Might just take off 0.0005 off the pinion and give it another try.
Im using a crush sleeve eliminator so makes these test much easier.
Fast69Mopar
The crush sleeve eliminator is the only way to go. It makes gear setup so much easier and faster.
Did you set the backlash at .006 or .0006?
The specs from the service manual are
.005" to .008".
You are spot on with the pinion Torque to rotate.
DILLIGAF
DILLIGAF
Canadian Forces
Canada
The crush sleeve eliminator nis the only way to go. It makes gear setup so much easier and faster.
.005" to .008".
LOL, one to many zeros... Y up its at 0.006.
Is 200ft-lbs good enough for the pinion bolt ?
Fast69Mopar
210 ft-lbs is the spec but 200 ft-lbs will survive all day long. No worries. I have had to set them as low as 145 ft-lbs and those trucks are still rolling. No worries man.
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Thanks guys , So many patterns online and none look the same... lol...
Im just glad I pull the diif out for my 1st attempt. I think I would of lost my mind if I had to do this under the truck in the driveway.
Tach_tech
5.7L HEMI
Ive seen much worse patterns be whisper quiet and last forever. You can spend all day trying to get a perfect pattern but usually close enough is just fine.
chri5k
USA
Diesel
I would have set the pattern a little deeper into the ring gear. The root of the teeth have most of the strength.
Bandit517
That Trials Guy
Wauseon, OH
From what I see, if I was to be SUPER picky. I'd say the pinion is a little deep, and I'd shift the carrier over a little to get more bit into the ring gear. But that's only if I was being overly picky. I've seen worse patterns, and even run them worse in personal vehicles in the past. I'd button that one up and call it a day.
DILLIGAF
DILLIGAF
Canadian Forces
Canada
I dropped the pinion to 0.0005 under of what is printed on the pinion and seem to have a better looking pattern now.
Fast69Mopar
Yeah man. That looks good. Do your break-in miles and then have some fun.
Fast69Mopar
Just put the diff back in today. Having supper anf will take her out for a rip.
Heck yeah. What diff and gears did you go with or did you go back with stock parts?
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Motive 4.56 gears,
Still debating what LSD to go with but Yukon seems to be the ticket.
Not sure why they list one for the 9.25ZF axle and one for the Chrysler 9.25 200$ difference but cant figure out why.
smoothee
St. John's, NL
Motive 4.56 gears,
Trutrac seems to be the way to go man, I'm savin pennies for it now. Lookin forward to how you find the gear swap, no flies on you! I've been wanting to do it for a lot of years, but don't know if I'll bother now with the 8 speed swap on the brain...
Fast69Mopar
Motive 4.56 gears,
Cool man. You will love the 4.56 gears in the RAM. It makes these trucks so much more enjoyable to drive. Every single RAM of mine has 4.56 gears except for my two Cummins powered trucks.
stevenmicheal
