Gear selection switches on steering wheel?
marine6212
I have the Alpha OBD2 and the OBDLink MX+.
Some how I deactivated my gear select +/- switches on my steering wheel.
Can some one point me in the right direction on reactivation?
Semperfi,
Marine6212
caulk04
Were you playing around with AlfaOBD? Hopefully you saved a copy of your stock config to compare.
M
marine6212
I don't see it in my stock configuration I saved!
clifford15
CTD
Best thing to do is download the current configuration then get Notepad++ on a PC and compare your original and new configuration. You might need to edit the new configuration file because the new data is appended to the end of the existing file.
M
marine6212
What should I be looking for? E-Shifter present?
ERS present? ERS switch/ inverter on/off switch input present? Performance shift enable CSM present? DTCM DRIVE TRAIN CONTROL?
M
marine6212
Enabled all the above it works now!
