Gears inquiry
U&A
2016 3500 SRW
6.4 HEMI
what are your rpms at with 35’s and 4:88? 55 65 & 70mph
I’m trying to decide on 4:88 or 5:13 with 295/70/18
Use the calculator. Add about 100 RPM for wind resistance.
Sent while firmly grasping my redline lubed RAM [emoji231]
Bldrinker
Here is stock vs 5:13 w 295/70/18.
4:88 with 295/70/18 looses rpm C08C8C80-2496-4B1C-8B49-D6AD72F14258.png
Mountaineer83
Charleston, WV
I have 275/65/20 which is 34 inches. Your 295/70/18 would be like 34.25 inche. Basically same as mine.
I had 4.10 stock, and love the 4.88s. Towing I may would have liked 5.13 better. But when empty, I love the way it drives now with 4.88s and I'm in WV as well, so lots of hills and mountains.
clinger3
Morgantown, WV
Mountaineer83: Happy with shops install and price? I'm in Morgantown and considering purchasing a 2017 3500 Cummins and may do a gear swap. Interested in "local" shops doing this work.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Clinger what gear are you looking for? I have my old 3.73's off of my 2500. If yours is a 3500 SRW I think the rear end is the same (10.5") Dell em' to ya cheap!
Ratket
Arizona-
@Mountaineer83
Sorry thought you where looking for Mounaineer”s Input.
Mountaineer83
Charleston, WV
I was very happy with his price and service. I had a noise not associated with the swap, but he even went for a ride with me trying to pinpoint it. He is a Ram guy himself and knows his driveline stuff inside and out.
The shop is in Charleston, but I'd recommend him hands down! I also have my 4.10s he took out. Trying to get my boss to put 'em in his Cummins.
The shop I used is Drive Line Service. Check out his Facebook page. Tons of cool pics and projects he has done . Guy is crazy about Jeeps as well.
clinger3
Morgantown, WV
Thanks! I'll definitely consider this shop if I go for a swap.
Not sure what I want at this point. The truck I'm considering has 3.42 gears. I plan to run 35 or 37's. I need to scan all the discussions regarding gearing.
Bldrinker
37’s on a diesel probably 4:56
G. Mcpherson
Yacolt, Wa.
2023 Ram 2500 CC SB Tradesman
Check out the Cummins Forum also. I am running 34.3 Tall Tires and just changed to 4.10 AAM. Much better all around.
Mountaineer83
Charleston, WV
I do have my 4.10s I took out. I'm in the Charleston area and he said the gears were mint. No problem putting them in another truck. Let me know if you decide anything.
Ratket
Arizona-
Seems like Mountain may cut you a sweet deal on them.... 4:10”s may not be a bad option.
