Gears
wickedwhite2012
Baton Rouge
I have factory 68053299ad lsd on order and i already have some factory 3.92 gears. What bearing kit am i going to need to have this installed?
meadows
ft hood
honestly i just had mine installed (literally over the long weekend) and the guy that did them ordered them for me. It was a kit. It cost under $200. Thats all i can tell you. if you absolutely need the info i can send you the number and you can call him.
JohnD72
Charleston, SC
What did you have installed and how much was it, with labor?
meadows
ft hood
I went from 3.55 open differential to new 3.90 gears and new LSD. ZF differential 2011+models. that's basically a complete swap and a rebuild. the prices were competitive......less than $1600.
Costa16
6cyl 3.7l
So you can't just swap the gears you have to get differentials?
meadows
ft hood
Use search. Also its differential. Singular. I swapped the guts of my rear diff. Thats the carrier and ring and pinion.
ATXHEMI
Round Rock Tx
If you have the stock LSD then no you don't have to "swap" the differential. But if you have an open dif(no LSD) then a gear change would be a good time to add one.
shaunnz
