Gen 4 MDS reflash
Z-Rider
How many have had the dealer reflash the computer to delete or cancel the MDS from activating? Any noticeable downfalls?
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
will they even do that? I thought most did that with an after market tuner.
Z-Rider
Z-Rider
I've heard that dealers can do it.....
xrsman
Ontario
3.0 Ecodiesel
Yeah your mileage will suffer. Why do you want to get rid of it?
MyOhFive
HEMI
Actually most guys report very little to no change in MPG... didn't know dealers would flash it off tho.
TXLimited
I turned mine off with my Diablo InTune, gained around 1.5 mpg (average) city and lost about 1 mpg (average) freeway. So many variables change mileage though, I just love the way the truck drives and sounds without constantly trying to swap to 4 cyl mode!
14hemiexpress
6.4l
Buddy of mine said the dealer couldn't do it his is a 08 though.
arod412
Philadelphia
Never heard of any dealer doing it. Why would a dealer turn off a Eco friendly feature?
Z-Rider
Z-Rider
Honestly I hate the feature. For where and how I drive it is constantly "searching" for the right mode to be in. Not to mention the truck sounds like it is on its last leg when MDS is on.
As far as gas milage, if I was worried about getting better milage I would have purchased a car not a truck.
xrsman
Ontario
3.0 Ecodiesel
Well you asked for downfalls so I gave you one. Other than that there aren't any
Jerry1984
Meridian, Idaho
If you have the 8 speed it's pretty easy to turn mds off. Just use the manual shift buttons to downshift then shift back up to 8 and it's off until you shift to park.
Z-Rider
Z-Rider
Completely understand, hope you didn't think I was being crappy towards you.
Z-Rider
Z-Rider
Nope, truck has the 6 speed
xrsman
Ontario
3.0 Ecodiesel
Nope I didn't , usually I have the radio on loud enough that I don't hear mine so it doesn't bother me! haha
Pull Ya
Cedar Creek, Tx
The dealers can't/won't turn MDS off. If you have a 6 speed if you drive in "5" or "6" the MDS will not come on. If you have an aftermarket exhaust and the MDS comes on, IMHO it sounds just like ****! You can buy a tuner and the tuner can be programmed to turn the MDS off.
Jay
jwheeler
Washington
Pretty sure the dealer can't turn it off. You need to get yourself some kind of tuner if it bothers you. Make sure the pcm software is up to date. There was a tsb for a flash for exhaust drone when in mds mode. I did it right after I got mine and it helped quite a bit.
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
use the manual shift buttons on the stick and keep it in a gear or use a tuner. I got almost 2 more mpg's by using a tuner
preachp
The Con State (CT)
Hi Z-rider.
If you shift down once so that the 6 is lit instead of the D then you will still have all 6 gears and MDS will be off. You have to do it each time you shift out of park but hey it will tell you if ECO mode is the problem.
Have a great day,
preachp
