General Complaints
Sasquatchtdg
Moncks Corner, SC
I love my 2015 Ram Laramie 4x4. Plenty of power, all features work as they should, very reliable.
BUT, this truck has more interior rattles than any vehicle I've owned. May just be my OCD nature but it grinds away at the love for this vehicle.
So far I've had:
Dash rattle - in the area of the faceplate surrounding the radio
Front windows - mysteriously gone away for the time being
Sunroof/ headliner - comes and goes
Rear seat spring - fixed
My 2012 with mud tires and dual dynomax VT with x pipe and 5" tips didn't have any issues.
My 2004 that saw more dirt roads than any of them had no issues.
My 1995 Dakota was abused beyond belief and it held up fine.
Did I just get a Monday or Friday build or is this a common complaint? Expected more from a $50k truck with under 100k miles...
Just venting...
CamperMike
Peoria, IL
Mine doesn't rattle much at all. The worst vehicles I've had for rattles were gm vehicles. Our Chryslers Fords and Hondas we've owned have had minimal rattles.
phantomfixer
Lakeland
I have a 2016 and it's never had a rattle of any kind
Fast69Mopar
So far I've had:
Just venting...
I have a personal habit of going through the entire interior so I can break a fasteners loose and re-torque them. I despise rattles. I will pull over on the side of the road to find a rattle and make it stop.
Milwaukee
2019 Classic
So far I've had:
Just venting...
Are you sure the rattles are coming from the truck itself? I thought i had a bunch of rattles too until i finally realized the rattles were coming from loose items i had in the storage areas..dip cans rattling in the center console, wheel lock key rattle in glove box, pens rattle in under climate control storage drawer.
The only issue i have is my passenger door panel buzzes annoyingly loud whenever there is bass coming through the speaker.. Any suggestions on how to fix this?
Sasquatchtdg
Sasquatchtdg
Moncks Corner, SC
The dash rattle is the bezel. Put a little pressure on it at the RAM tray on the top and it stops, let go and its back. Already taken it apart once, I'm seeing some caulk strips or adhesive felt in my future. Or have someone from the automotive plant I work at moonlight and check it out. I know they bring quality marks up if there's any noises on the test track.
Sasquatchtdg
Sasquatchtdg
Moncks Corner, SC
My 18 is quiet ,I've had it for 2 years.
If I can find an 18 that is the color, trim, mileage, and price I'm ok with, I'd seriously consider a trade in. Apple carplay is the big factor there, the newer grilles are not my cup of tea though.
retired
montana
So far I've had:
Just venting...
I don't think that is valid anymore as they run 7 days a week 2 or 3 shifts. there is a decal on your door that will tell you when your vehicle was made down to the hour. MDH is month day hour
tron67j
Maryland
For the bezel, if you bought truck used it is possible the former owner had aftermarket radio then put original back in before selling. There are like 14 screws holding interior bezel to exterior part of bezel, possible that not all screws were put back and/or tightened.
Quyonmob
Canada
My double din head unit required a bracket be cut for clearance. I get the odd rattle from it, not a lot though.
now the ******* clock spring in the steering column makes constant noise over bumps straight, and even on smooth turns.
RamInfo
Utah
5.7L HEMI
My 2016 has had one annoying rattle since day one—the handle for the flip-up lid on the flip up seat console. Putting even a slight amount of pressure on top stops the rattle, and I can’t find what is loose or any way to tighten it.
It’s not bothering me as much now as it rattles a lot less since I had my Michelin DefenderLTX M&S installed—they are much smoother than the OEM Wranglers.
best,
DG
Brian2081
Weatland Michigan
Good Afternoon All, I have a "16" 2500 CCLB, bought used had 1 annoying rattle. Found the instrument cluster was missing the 2 upper screws that hold it to the bezel. Dealership does not have a listing for these screws.
The only other annoying thing
Brian2081
Weatland Michigan
Darn phone looked up. Anyway continuation of my last post, drivers door bangs when you hit washboard type bumps or big bumps. I can make it stop if I put my fingers the door and door jamb at the top rear corner.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
Nothing on my 2011 until
A few months ago. Found out the rear springs started rattle over bumps.
bchap05
My 17 is rattle free. However I now how a click when I turn the steering wheel. I think the clock spring is messed up or something. Might change he wheel out to a leather one. Or maybe its just something loose in there. Not sure only does it if turning, banging on the wheel area does nothing.
Wifes 18 Durango has a door rattle that happens from certain bass that is annoying.
Narg
Tulsa, OK
5.7 eTorque
I had two quiet GMs before my 2020 RAM. So far no real rattles, but a slight spring squeak from driver's seat. But that's what a good stereo is for, right? :)
Marshall
Sk, Canada
2014 sport
My 14 is good, a bit in the dash, but a lot of crap in the glove and center boxes .
Thought my 2010 Laramie was great also, than got hearing aids , Damn, rattle in the dash that the wife said has been their for a while, But about that time a brain dead chev guy playing on his phone hit me at 100KM, so that fixed that. My 14 sport is better than the wife's Honda CRV that was new. Roard noise, wind noise lower front that the dealer can't fix.
mtwofeathers
Kingman Arizona
Diesel 5.9
So far I've had:
Just venting...
My 2007 had one rattle that took me 9 moths to find. It was a set of extra keys under the carpet under the rear seats. Did not make sense to find them their. Batteries were dead but key still worked after new batteries. Just strange to have a extra set, im the first owner too, truck had 68.5 miles when I got it.
