Gofishn 2014 Ram 1500 Express Crew Cab 4x4 Cherry Red Build Thread
atc250r
Orange County, NY
Just wanted to say thank you for this thread. Lots of great info and interesting ways for me to spend even more money on my truck. :p
VaDimZH
WA
5.7L HEMI
Thank you,gofishn,for a great thread! A lot of great information!
BobSacomano
North Texas
3.6L V6
Yet another Mod, Change, Alteration, to my Truck I had completely forgot, all about.
Disable the Seat Belt Chime
Found it here:
http://www.ramforum.com/f76/seatbelt_chime_delete-28510/
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. DaimlerChrysler does not recommend
deactivating the Enhanced Warning System
(BeltAlert).
1. With all doors closed and the ignition switch in any
position except On or Start, buckle the driver’s seat belt.
2. Turn the ignition switch to the ON position and wait
for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of turning the ignition switch to the
ON position, unbuckle and then re-buckle the driver’s
seat belt at least three times within 10 seconds, ending
with the seat belt buckled.
NOTE: Watch for the Seat Belt Warning Light to turn on
while unbuckling and off while re-buckling the seat belt.
It may be necessary to retract the seat belt.
4. Turn the ignition switch to the LOCK position. A
single chime will sound to signify that you have successfully
completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated
by repeating this procedure.
By the by, biggest reason I created this thread was for myself.
An effort to keep track of what I did and how I did it, in case I needed to do it all over again. the fact that others can learn form it too, is a plus.
If I could buy you a cool one for this post, I would.
I wear my seatbelt most of the time, but I'm constantly moving the truck in the driveway (depending on whether my wife or I wants to use the garage), dropping off recycling and lawn trimmings at the recycling center down the block, etc... and I really didn't need reminders to buckle my seatbelt in parking lots and alleys at 8 miles per hour.
I did this and it worked, first try.
THANK YOU.
