Got a Vibration Now?
1NastyHemi13
Hey guys, Went out this weekend to a place called Yankee Lake Truck Night. Took my Truck off road a little bit nothing crazy just through the trails which wasn't bad at all. Played around in the mud for a little bit an that's about it. Driving home I noticed that the truck wasn't as smooth as before at highway speeds. Before you leave the place you drive through a wash pit that sprays your truck off some. Cleaned it up the next day best I could at home. But I noticed today again at highway speeds that its got a vibration no sounds just truck vibrates most noticeably around 75mph. Any Ideas of what to look for? Thanks.
Badunit
6.4L Hemi
The first thing to look for is mud in the rims. There is a lot of flat space on the inside/underside (whatever that the part of the rim is called) for mud to get stuck.
Mr. Crowley
Corpus Christi TX
2011 2500 4x4 Crew Cab
5.7Hemi
Could also have easily thrown of a balancing weight from one of your wheels.
charonblk07
Calgary, Ab
F1-A forged 349ci
Most likely there's still mud in the wheel behind the spokes, quite a common issue, but a tire weight is also a possibility but much less common.
ramenthusiast
Banned
W. Palm Beach, FL
2012 Crew Cab Sport
It's got a Hemi!
While checking the wheels, make sure the driveshaft u-joints aren't packed with mud.
Adept
4.7L v8
My truck rattles n shakes all the time but it's lifted and I always take it off road.. but yeah check the weights on your wheels
Sent from my HTC6435LVW using Tapatalk
jcat
I'll guess wheel weight too. Stick on weights suck.
1NastyHemi13
First I'd like to thank everyone for the suggestions an replies to my post. After work I pulled her into the lift an rotated the tires, I hosed off a bunch of mud caked around the wheels mainly the two fronts. Remounted the wheels back on torqued them down. Soon as I jumped on freeway I knew that the vibration was gone. I'm so happy my truck is all smooth again!! Yay!! I contribute my lack of knowledge to this being my first time off roading. Lesson learned. One another positive note I am super happy with how well she did mudding. Can not wait to lift an get some aggressive meats next. Then she will be a monster!!
shaunnz
