Got the 3 inch body lift installed!
ilovemyramlaremie
Moravia NY
Been wanting to do a lift kit on my truck for a while now but, was always undecided on 4 or 6 inch suspension lift, I really didn’t want a to tall truck, I’m 55 years old . I leveled the truck with the bilstine struts set at 2.1 couple years ago, so finally I pulled the trigger on performance accessories 3 inch body lift ! I’m happy with the results, a happy medium on the lift, I can still get in and out lol.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Looks good !!! I will be adding a 3" body lift on my truck if we end up moving from this house since I won't be able to fit it in the garage where we will be moving to ... looks like a shop did it correct? How much did they charge you ?
Activate
The Netherlands
2015 and 1998
360 and 410 with SC
I als0 did a PA 3"body lift and was happy with it!
Also installed last week a 4"lift, was no too difficult to do also in my own garage.
2018 2wd
No shop lol. My personal garage, I got a 4 post lift lol. Did it myself.
Nice .... it doesn't look like rocket science which is why I am going to do it myself too ... might just wait til my 37" tires need to be replaced because I would like to go up to a 40" tire if I add the 3" body lift ..im already at 7" with 37"s right now ...
Did you notice any tension on any of the harnesses up front?
ilovemyramlaremie
ilovemyramlaremie
Moravia NY
Just on one front ground strap on the driver side above the front tire, when I was lifting the cab on the driver side quite high, about 6 inch, to fit the steering wheel shaft extension, it was a pain, i was wrestling With it for a little bit, but finally got to high enough to get it to fit. No damage though
ilovemyramlaremie
ilovemyramlaremie
Moravia NY
No. Just on one front ground strap on the driver side above the front tire, when I was lifting the cab on the driver side quite high, about 6 inch, to fit the steering wheel shaft extension, it was a pain, i was wrestling With it for a little bit, but finally got to high enough to get it to fit. No damage though
Activate
The Netherlands
2015 and 1998
360 and 410 with SC
Me and my buddy did it in about 6 hours, no problems at all, the steerings shaft was also easy we could move it upwards the colum.
G-Ride990
Administrator
Administrator
Chandler, AZ
This is just bils and a body lift? Looks like much more than that to me. Nice job!
tones2SS
MA
Very nice.
Looks great.
atreides
USA
Man you guys are lucky. My ******* didn’t check the steering shaft as I raised the body… the lower shaft stuck in the steering assembly and pulled out of the column. Getting it unstuck, back in the column, and fit with the extension added an extra hour to my install. LOL
LeeS
Gibsons, BC, CANADA
3.0 EcoalDiesel
Here's my 2015 EcoD 4x4.....3" PA Body Lift with Eibach lift strut kits at 2.5 inches....1" Eibach rear lift coils with Bilstein 5100 shocks....Timber Grove air bags.....295 60r20 WildPeak AT on Mayem Arsenal 20x10 -19's....1.5 " Bora Spacers for aggressive stance
