Keith67
I was looking for the front driveshaft joint to grease in my 2021 PW (I greased that in my 2018 2500 Cummins) and discovered it’s a sealed joint now, no grease required I guess. However, I found a lot of grease outside of the rubber boot and a bunch more slung around under the truck. This is the front joint coming out of the transfer case. 15k miles on the truck.
I wiped off as much as I could from inside the rubber boot and I couldn’t feel or see a tear. This isn’t normal is it? Assuming a warranty trip to the dealer might be necessary. No unusual noises in 4WD.
