Grille Compatability
moohampshire
I am looking at putting a chrome Grille of a 2017 onto my 2015 tradesman that has the black grille. Will the 2017 grille fit?
Yes. FYI if it's the chrome slat grill,you'll lose some airflow across the rad compared to the more open honey comb style grill which you have in your tradesman,if it's the chrome honey comb grill there's no differance in airflow though.
hunterdan
SE PA
2019 classic
The slight loss in airflow is negligible. Especially if he has ags.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
2013 - at least 2017 Ram 1500s are shaped the same
look at the bottom corners, they are cut off
2009 - 2012 1500s
I tend to disagree,especially if you do any amount of towing.My truck originally had the sport grill,when i switched to the honeycomb grill it dropped the temps a few degrees.Compare the holes in the 2 differant style grills,not a chance in hell the slat style grill is going to flow the same amount of air across the rad and through the engine bay,even with the shutters.The shutters don't cover the whole rad,the bottom of the rad is still uncovered
Administrator
Any '13-'18 (and Classic models) 1500 truck grills are interchangeable with each other, the exception being the Rebel/Warlock grills. The Rebel/Warlock grill are part of the front bumper design, but you could swap the bumpers if you wanted that front look.
M
moohampshire
Thank you for all your help on this matter. The one I am looking at is the honeycomb stile
