Grille removal help
RompinRam
Hoffman Estates, IL
4.7 Magnum
Alright so I'm trying to take my grille off to paint it and I can't get these damn bolts off. what have you guys used to take them off
RompinRam
RompinRam
Hoffman Estates, IL
4.7 Magnum
Yeah It just looks like his unbolted no problem. Mine are just like spinning. Wasn't sure if anyone else had this problem
Trupiano
Registered User
6.7L CTD
Ooh I see. You have to hold the bolt with a small socket or wrench, then use another wrench on the nut.
Basically you have to hold the bolt/stud from spinning, while you unscrew the nut.
RompinRam
RompinRam
Hoffman Estates, IL
4.7 Magnum
Yeah that's the problem. I don't have anything small enough to hold the end haha. I'm gonna head to my buddies shop n see if he's got anything. I might just order new ones and cut the old ones off. Anyone know where I can order new hardware?
RompinRam
RompinRam
Hoffman Estates, IL
4.7 Magnum
Tried vice grips. No go haha. That's why I'm thinkin about just cuttin em and buying new ones.
mrfyram1500
2024 1500 Laramie
Ohio
I had the same problem on my 08. I sprayed them with penetrating oil and let them sit for a few minutes. If that doesn't work, don't cut them. These are actually threaded into a plastic clip. It's specially made clip for the grille that I couldn't get from the dealer. It may seem like the whole thing is spinning, but it actually is threaded on the end you can't see but will still come out.
bigbadram1500
Springfield, IL
A couple of mine were like that too. I used a needle nose pliers to hang onto to the screw.
