Ground force 2/3 or belltech 2/4?
1SloRam
Ms
Everything here in Alberta is pretty well a Sport or higher trim level truck,very few tradesmens or slt trucks. R/T's are very rare in Canada,as you can hardly give a 2X4 truck away up here. When i bought my truck,i actaully wanted a R/T ,and had the dealer do a Canada wide search for one,there wasn't one available at any dealer in Canada at that point in time,now i'm glad there wasn't,as that was before the driveshaft issue the 2 wheel regular cab shortbox 8 speed trucks have, had become common knowledge
Yeah the 6spd R/T’s didn’t have that issue, had one of those before the one I have now. Got totaled. I’d like to have 8spd but my 6spd hasn’t let me down yet. Just waiting for a new cam atm.
Midnight Storm
Midnight Storm
One Badass Ram
Victoria, B.C Canada
There are maybe two sports here, all 4 doors. Only one R/T in town, rest are tradesmen.
I monitored my gauges for a week after the swap and didn’t see any real difference.
I’ve debated swapping back when I repaint the truck and ditch the chrome.
Love the red rig you got!
plasti dipping the slats make a big change. I’m the only one in town that I have seen. Looks stealth!
2859F827-9F8E-469A-BC03-D19AFA413435.jpeg C10169EF-274A-43AA-87B8-014C997B9543.jpeg
spymac
2011 Express
Hemi 5.7 - 390HP
Does your kit include the brackets to relocate the rear locating arms,if not,they're worth having.The rear suspension geometery really goes out of whack when you lower a 4th gen. I'm running the older Illicit brackets,but the Inez brackets do the same thing .You can see where the arms sit with the brackets in these pics
What lowering kit do you have installed? Love the look! I had a belltech kit but removed it because I couldn't stand the ride. But I miss being lowered and am hoping there are some better options now than there were years ago.
I'm running narrowed drop spindles on the front and cut down factory R/T springs,truck rides better then my wifes Challenger does. Spindles have been narrowed roughly 5/8" on each side ,to bring the front wheels back in,as the spindles move the wheels out roughly 3/8" on each side.
Mike Thacker
Houston
2011 RCSB
HEMI 5.7
What size tires do you have?
I went out and found some Sport wheels. Probably will do 305/50/20 rear and 275/55/20 front.
Jessica Smith
Houston
I'm surprised, so when you say rides better, do you mean better handling or from a stiffness point of view?
I understood that when you cut down a spring, it increases the spring rate, so would make the ride harsher. I'm trying to investigate if lowering springs are available that can preserve a cushy ride, or if that's asking too much.
1SloRam
Ms
My belltech 2/4 with relocation brackets rode like stock, if not a bit better cause you get less body roll but doesn’t beat you to death like some lowered trucks I’ve been in. I didn’t upgrade shocks either, but Viking adjustables seem to be the best option. QA1’s supposed to be good too.
R/T springs are progressively wound on the top end of the coil,that's why they have a lower payload then a normal regular cab shortbox has.You can cut a fair bit off their springs before they start to get stiffer and the ride gets rougher. I don't run front swaybars on any of my toys,including the truck and the wifes 1320 Challenger,they still go around corners pretty decent.And i live where you can really push things in a corner if that's what you want,lol
1SloRam
Ms
You don’t run sway bars cause you bout that fast life, haha. Track habits die hard huh.
Mike Thacker
Houston
2011 RCSB
HEMI 5.7
With the adjustable Core4X4 arms, I was going to see if it will be OK without the brackets. If not I will probably have a shop fab some custom brackets on the axle. The relocation brackets look thin compared to the factory metal and I may have a custom rear bag mount made at the same time.
MCM, did you use the Core adjustable arms? Did you have some brackets fabricated or use the stock location
MCMLXIX
Las Vegas
5.7 HEMI R/T
Hey Mike.. I'm still waiting for my custom front adjustable upper control arms from Michigan Metal … so nothing has been installed yet as I want to do it all at once.... I did reach out to Moe's Performance and have the CORE4X4 Tier 3 adjustable rear arms and the Tier 3 adjustable panhard bar waiting it go on the truck...
