Ground locations
RustyRamFan
Knox Indiana
Trying to make a complete list of ground locations for these first gems
Right now I got:
One near windshield wiper motor
One right of the steering column
Two near battery negative terminal
Ground behind #6 valve cover
One on the alternator
One on the thing that looks like an alternator but isn't
One near the starter relay
One behind the radio
The two horns are grounded to the frame via the mounting bolts
There isn't one on the starter itself
No grounds on the tranny or transfer case
I think theres a ground near the tail lights
Any grounds I'm missing?
RustyRamFan
RustyRamFan
Knox Indiana
Apparently theres a ground either near the right headlamp or near the center dash panel.
Tonycarrillo
Davenport iowa
Hemi 8cyl
My 1500 dodge ram fist have no intermittent light for show the direction we’re I want to move, only when I conect the trailer the lights work! I now i open the fuse box and clean have a lot rust on it and work perfectly in like 12 hours and now mi dashboard have intermittent on and off! Somebody can tel me if the ground cable have an important role o ln this! The rust color is like blue!
Daw14
South Florida
Yes a clean ground connection is very important . You have an old thread here , next time start a fresh one of your own .
PeterWV
WV
Blue (almost a blue green) is corrosion-- very bad for grounding wires.
