Hard Wire Radar Detector.....uggghh
warv3t
North Carolina
Got my handy dandy hard wire kit......has a cool lil inline fuse so I don't necessarily have to use an "add a fuse" from the auto store.......came with a lil t-tap connector that allows me to tap into a wire, which I wasn't going to do.
I was going to get an "add a fuse" and do it that way until I just noticed......there is no fuse box inside? It's only in the engine compartment? My kit/wire is long enough to reach there and I can actually use a "add a fuse" ......or I can tap into a wire, but where? I took the panel off inside, nearest the door and see wires in there.......or should I run it to the fuse box. And where should I route it into the engine compartment from the inside of the truck if so?
uggggghhh
hotrod45
Home
If you go to the fuse block, it is more likely to be a clean install. Tapping into a random wire somewhere might tell the computer something is wrong.
W
warv3t
North Carolina
Ziezee
Washington
Use the plate that covers the hole where the clutch would go through.
I need to go through the firewall with two 12 volt lines for my amps.... Clutch plate sounds good. Where is it located... I haven't looked yet. Maybe it's easy to spot. Will check tonight.
These fuses are different that my old vehicle. My old pack of "Add a Fuse" is incompatible. Does the Mini Add a Fuse work in a Micro? I don't see Micro's on Amazon... Currently, my hardware solution is a wire wrapped around the unused accsesory fuse. I'd rather have it on an Add a Fuse though...
Outbreak
Cummins 6.7
I just added one of these off of my battery (using a main switched relay that only powers when the truck is running), then added my switches for my lights, radar detector (can't use on military base) and extra usb ports.
https://www.ebay.com/itm/Car-Fuse-B...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
View media item 25775
RevRonnie
I tapped into the over head console ignition wire for the sunroof. Works fine for me.
IwantaRAM
Santa Barbara
2018 Power Wagon
Hemi 6.4L
JB1
Houston, Texas
Im pulling an antenna, and sPOD cable through this piece. I currently have a small, what looks like audio cable, that is all ready pulled through the plastic shield. Anyone know what that wire is running to? I can post a picture later today.
View attachment 158555 View attachment 158556
Any wire going thru that plate is not OEM, that's the clutch pedal delete plate. You should consider using a wiring boot
https://www.ramforum.com/threads/in...wires-into-the-cab.117923/page-3#post-1968127
wink
Beast Pilot
Golden, Co
2017 1500 Sport RCSB
I just tapped into the mirror harness. Nice and clean. Been there for 9 months and no issues at all. Did the same with my Jeep, and it was trouble free for 8 years.
wink
Edit: I give up on posting a pic...
JB1
Houston, Texas
No amp powersteps or anything like that?
