After a month of keeping my battery connected to a battery tender and feeling like this solution was going to last forever, I had a jaw dropping moment when I FOUND THE CAUSE OF MY BATTERY DRAIN! I have a problem with mice getting into the engine compartment and cab and was convinced that these little rodents had chewed through some wires and it was going to cost me an arm and a leg, not to mention time at a shop, to get this problem tracked down and repaired. I had read through every post on this forum and another Ram forum trying to find the answer myself. I found that many owners isolated the problem to the radio and was prepared to pull the fuse and run an amp test to see if that was my problem when out of the blue I began to think that the one area I hadn't checked was the factory sub woofer under the backseat. I envisioned that mice had gotten in there and chewed through those wires so, I proceeded to unbolt the unit and pull it out just to see. Much to my surprise, when I pulled the unit out I found that there was about 4 inches of water in that recessed area where the sub sits and the connector plug was completely under water. I disconnected the plug, pulled the unit, unplugged the battery tender and let my truck sit overnight. Tried to start my truck the next morning and it fired right up! I drained the water out of the recess, reconnected the sub woofer, and again let it sit overnight and next morning it started right up! It has now been two weeks and the truck sat for 5 days at one point and I had no problem with it starting. Now, as for the water problem, that damn gasket around the third brake light appears to have been the problem. I just replaced that yesterday and we are expecting rain turning to snow today so we'll see if that worked. If this post helps just one person find their problem I will be happy!
